Old 07-30-2021, 03:10 PM   #55 (permalink)
Piotrsko
I'll add: your phone doesn't draw 800 amps to produce a couple hundred KW dissipated. And 100% indicated charge is about 4.2v per cell, mine is 3 cell in parallel but still 4.2 max voltage oyherwise you'd need a buck inverter in the phone because supply maxes out around 5 volts except for the really new stuff running USB "C".
