Old 07-31-2021, 10:12 AM   #7 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
First, OE tires are designed to the specs published by the OEM and those specs have fuel economy (rolling resistance) in mind. They can do that by sacrificing treadwear and/or grip.
Consumers don't generally care for bad wearing tires, so there will almost always be a hit in the fuel economy department when replacing OE tires.
One of the things that affect rolling resistance in tires is the amount of tread rubber - meaning that luggy tires - the ones good for gravel, mud and snow - are worse than all season tires.
Also going larger will help RR - a little bit - but those other things have a much larger effect.
So there you have it. For a heavy duty truck, you just don't have much in the way of options.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
