Old 08-02-2021, 03:27 AM   #368 (permalink)
freebeard
Back in the good ol' days of the first home computers in the 70's, less than 100 watts was quite common (IIRC).
512K Macintosh Max Watts: 60 / Amps: .5 / BTU per Hr: 205.2
About as much power as a 60 watt light bulb, and maybe the light of a 15 Watt light bulb.
....retro games and play them on hardware based systems
RetroPie - Retro-gaming on the Raspberry Pi
https://retropie.org.uk
Welcome to RetroPie. RetroPie allows you to turn your Raspberry Pi, ODroid C1/C2, or PC into a retro-gaming machine. It builds upon Raspbian, EmulationStation, RetroArch and many other projects to enable you to play your favourite Arcade, home-console, and classic PC games with the minimum set-up.
https://www.thingiverse.com/search?q...&sort=relevant
edit:
mini Commodore PET! + A brief history of PETs!
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
