Old 08-06-2021, 05:33 PM   #272 (permalink)
aerohead
not part
So... They're not part of the invariance.
I know you're a fan of the inverse square law. Here's an interesting question:
Piotrsko should like it because it's not copypasta. I expect a tutorial [series] on how to animate the waveforms and bullhorn. www.youtube.com/c/CGMatter/playlists
(the an answer is in the comments on the Youtube page)
1) they would not be a component of total solar irradiance. And total solar irradiance doe vary, so, they would not be part of the variance.
2) they would be components of the solar wind, flares, CMEs.
3) if an accurate magnitude ( say, sound pressure level, on the C-Scale ) is obtained at a given distance, running the distance and math backwards will deliver you to the original signal power level at the source. It will be 'geometric', not 'infinite.' Infinity cannot be quantified.
