Old 08-06-2021, 07:08 PM   #24 (permalink)
Gschuld
I could do that…. and I might soon enough.
I am pondering a bunch of factors that are pulling my designs in opposite directions.
Once at the track, I’d be spending 3-4 nights there. Most either bring RVs pulling a small/mid sized enclosed cargo trailer for the bikes, equipment or drive trucks/SUVs pulling a 7x14 or so cargo trailer that they sleep in when the bikes and stuff are outside under 10x10 EZ UP tents. Some use large transit vans for an all in one setup. Almost everyone has air conditioning. More than half the events are in the south. And it’s a summer sport for the most part with a few races spring and early fall.
There are a number of tracks with electric hookups available, but demand far outstrips supply and those few spots are not easy to get. So you end up with a sea of small to mid sized inverter generators running all day, and often at night if it is over 75 degrees at night.
Cargo trailers are rarely used during the day even with the AC running because there are few windows and you feel like you are in a large dark closet. At night that’s fine(ideal even)
I’d like a space that I can ideally once at the track have standing headroom(I’m 6’3”) and be set up so that it’s a pleasant place to be during the day. Some windows are key here.
My wife’s version of going to the track is to be able to spend a decent amount of the time inside, with the AC on, sitting somewhere relatively comfortable and reading a book/listening to music/using the internet, etc. A high quality HEPA/activated carbon filters combo plugged into the intake side of the AC would help greatly with the inevitable fumes in the air from the generators and race bikes running race fuel.
To accomplish this, I’d need an expandable (in height) trailer design if I am to keep the frontal area of the trailer close to the frontal area of the Jeep for highway drag reduction. Several ways to go about this, and all have their drawbacks.
From a custom HI LO design, to a front hinged roof lid that created a standing headroom at the back, and several novel designs in between.
With any of these a reasonable amount of sound and or thermal insulation is challenging at best. Some more complex than others.
Another factor is the other potential uses of the trailer when not going to the races. Perhaps some traveling, moving things locally, etc. 24/7 standing height would definitely be more ideal there.
Another factor is security. Having the ability to secure the trailer helps. Several racers have had their trailers stolen or broken into when they have stayed in motels/hotels on two day drives to and from the track. I’m hoping to avoid that situation entirely if possible.
So there are two ways:
A full standing height trailer with a design to limit the full height to the centerline portion to minimize frontal area with a tapering tail and all the other tricks to make the best aero I can muster.
1- easier to build
2- lighter weight
3- far more sound/thermal efficiency (more comfortable and makes heating/cooling simpler)
4- more useful without needing to mess with a variable shape
5- easier to secure
6- lower aero efficiency potential
And an alterable design that is low on the highway, and converts to tall at the track.
Pretty much the opposite of the above.
So if I could wave a magic wand, I’d be able to lay out several designs and be able to get Jeep/trailer CD and highway MPG numbers for each. And if the difference is small enough I’d likely go with an optimized full height design.
