Old 08-10-2021, 09:32 AM   #8 (permalink)
Piotrsko
Originally Posted by rmay635703 View Post
Range yes right OEM from the factory
Speed sadly no, the hub motor self limits to 33mph because of the voltage of the pack, would need to replace battery + controller + battery which on one of these things is more than the moped
On my $40 craigslist bike hubmotor kit, the controller rated at 24 volts actually accepts 36 nominal, and the hardware is actually good to 60 if I wanted to do a boot swap on the control parameter. ( based on the power chips painted id numbers) New unlimited 80 volt controllers are a buck fifty, but decent battery cells are expensive or really big & heavy. The 80 volt one I found also doesn't need hall sensors in the motor so it only can sense output frequency for speed. Buy a 20" hub and lace to a 28 wheel and use pedal crank sensor only.
Sadly, doing all this means I need a trailer, because my bike is full suspension. Nowhere on the frame to hang more than 36v 10ah lipo.
