Originally Posted by hayden55
Redpoint does your utility companies have minimum charges?
The meter fee is $11/mo; the price of being physically connected to the grid and maintaining an account with the utility.
Originally Posted by Piotrsko
Why does solar have to be on grid, especially if you have an electric car? I was thinking of adding some panels to run stuff and charge the ranger, but then the thought hit me: I'm retired, I can charge during the day and back feed stuff from the ranger at night. I sure as heck not going to bother with telling NVENERGY or even the city building dept.
Modern meters won't run backwards unless they are programmed to do so. The old physical meters often could be run backwards without the utility finding out, so long as you showed some net consumption every month.
My meter was replaced with the exact same model, but apparently it was programmed to "net meter" rather than run in only one direction.
