Old 08-15-2021, 12:01 PM   #1 (permalink)
67-ls1
Eco Rodder
Front air dam vs underbody belly pan
On an old car, in my case a 1966 Chevelle, with a horrendously shaped underbody, is it better to use an air dam to try to keep the air out or try to fab a belly pan?
I already have an air dam I’ve made for the front so would it be worth it to remove it and smooth the underbody?
The Chevelle is a full framed car with dual exhaust the full length, two relatively huge mufflers, I live rear axle. It’s a mess. It would require a LOT of framing to support it and I’d still have to leave the exhaust area open.
This is more for mpg than downforce.
Opinions?
ID:	31146   Click image for larger version
Worlds highest MPG LFX V6 powered 1966 Chevelle
The Following User Says Thank You to 67-ls1 For This Useful Post:
aerohead (08-18-2021)
