Old 08-17-2021, 04:15 PM   #1106 (permalink)
freebeard
Make the rings out of angle metal then you just need a drive and grease.
Chevron-cut [3D printed] planetary gears act as a thrust bearing.
Herringbone gear
A herringbone gear, a specific type of double helical gear, is a special type of gear that is a side to side combination of two helical gears of opposite hands. From the top, each helical groove of this gear looks like the letter V, and many together form a herringbone pattern.Wikipedia
'Cold dead hands' isn't on everyone's mind, apparently.
