Old 08-19-2021, 07:43 PM   #40 (permalink)
cRiPpLe_rOoStEr
A hybrid will get more miles per gallon so needs a smaller tank to go the same difference
Not so much better on highway.
and that battery has to go somewhere.
Considering the rear suspension switched from the sedan's multilink IRS to a torsion beam due to clearance issues which would decrease the trunk capacity, presumably it would make sense to use a smaller Lithium battery such as the one fitted to the Prius C and 7-seater versions of the Prius V instead.
