$80 for a panzer pan?
Mileage sounds a bit low at 70. On the beer run from Reno to Seattle/Vancouver we were averaging close to 49 (53 if you believe the onboard indicator) running with traffic on I 5 which wasn't the speed limit. Was much better before the software change as we needed to refuel just before Seattle where before we could almost make the border. Could be in the 700 mile/tank club if I wanted to drain the tank dry.
'13 neutered, Manual trans, performance/handling tires, no mods, no drafting. Was running the lower grill block. Can't believe the slush box is costing that much efficiency.
Watching this because I'm going to steal what works if it's not intrusive to the wife particularly if it fixes the #@&%€ dirty as heck rear window. Lusting on adding a front splitter kit with added gurney flaps since they are only $80.
