Old 08-21-2021, 10:27 AM   #106 (permalink)
Piotrsko
I wonder how costly it would be to install smart water meters that can report wirelessly like power meters? It would need to stick out above the valve box in the ground, so that's a little tricky. It would allow people to see real time use though and probably help many people identify leaks they weren't aware of.
Can't be that expensive since they are retrofitting them in Reno. They don't need to be aboveground except for the antenna module which is flush with the access cover. They talk over cell phone every so often. That was the limit of the techs knowledge. I have no realtime access to the data and none is planned. They suck for leak detection unless you wait a good long while for the units to tick over that 1/10th gallon. I miss my old one.
The water company says the majority of use here is watering the grass.
redpoint5 (08-21-2021)
