Old 08-21-2021, 01:53 PM   #102 (permalink)
EcoCivic
I've seen maybe 1200rpm in my stock Insight and 1000rpm in my K swap. Higher idle, yes, but certainly not 1800. VSS is still not connected to the ECU?
The VSS is connected to the ECU, I reconnected it because it wasn't going into decel fuel cutoff or activating VTEC with no speed signal. When the ECU isn't receiving a speed signal, the engine idles properly while coasting since it doesn't know the car is moving.
