Old 08-22-2021, 11:02 PM   #109 (permalink)
freebeard
I looked back to see if this is the thread where I documented the technology to super-clean heat exchangers. Instead I found Permalink #84.*
The linear boxer configuration provides overlapping phases of compression, so no startup spike in load. I want to retrofit my two-cylinder air compressor, the one with the 60-gallon tank that needs a new AC motor. Basically scrap everything but the tank and the wheels.
*Since I mentioned the 14th Century treasure fleet, I learn that the CCP have closed their 2nd largest container shipping port over one case of a vaccinated worker falling ill. If true, this is the modern-day equivalent of the retreat into the Hermit Kingdom. One can hope.
The wages of woke is broke[™] -- Harvey Cthulhu
aerohead (08-25-2021), redneck (08-24-2021)
