Oil level resistance
Oil level is one place to get fuel savings. More oil means more default resistance to engine.
Basicly engine producer has given accepted max-min level of oils. Basicly producer would accept continuous min level run.
Double saver is oil pressure warning, but it is a good idea check oil level often if you try. Fill a bit more if engine get more noisy.
Using 0W oils and middle oil level I have achieved about 10% savings were achieved when used in city short runs of 6 mi (10 km).
Has anyone else tested oil level effect?
| 107  | Espace 3  |
