Old 08-23-2021, 05:04 PM   #6 (permalink)
Piotrsko
Not every modification. If you straighten the flow before the throttle plate you might see an efficiency gain because it isn't turbulent at the map/maf sensor and so could signal leaner operation. You can also get a pressure boost. I suspect the throttle plate causes swirls and eddies even full open
