Old 08-25-2021, 12:18 PM   #105 (permalink)
oil pan 4
Originally Posted by Isaac Zachary View Post
I've understood the DPF doesn't have a huge effect on fuel consumption on most big rigs unless not maintained properly. The thing is that if used for long distance driving it incinerates it's contents without the need for active afterburning. But for short routes, yes, it needs to regenerate by adding fuel.
Tip for all you newer diesel owners. Wrap up your exhausts with heat tape. Diesels don't have as high exhaust temps as a gasoline engine does so wrapping exhaust post turbo won't hurt anything while also keeping catalytic converters and DPF's hotter so you end up needing less fuel to regen and you also keep things less clogged with suet.
The dpf regeneration burns fuel. Ford specifically says in their early dpf trucks that regeneration cycle can burn 17L of diesel fuel. What a waste.
