Old 10-06-2008, 01:09 PM   #13 (permalink)
TomO
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Originally Posted by Dust View Post
I:m looking for way to get it mounted. PVC to plastic, plastic in DIN. I guess I should look for a 2.5 by 2.5 spot to put the gauge, or just buy a pod for $10. What kind of glue did you use for the PVC to ABS mount?
I used PVC cleaner on the ABS and The PVC, let it dry overnight and then glued the PVC to the ABS via Gorilla Super Glue. I attached the ABS/PVC assembly to the DIN opening via 3M double sided foam tape, some of the stringest, cleanest removing double tap there is.
