Old 09-03-2021, 01:02 PM   #7 (permalink)
aerohead
outer portions
Originally Posted by 67-ls1 View Post
The grill opening aligns with the middle part of the radiator. Roughly the middle 3rd. The upper portion is covered by the leading edge of the hood and the bottom portion is behind the bumper.
You can see in the pic below that there is quite a bit of grill opening on either side of the radiator core. I can block that and roll the block back to the core support.
You can also see that about half the bumper opening align with radiator. As an alternative I could just block the outer portions of these openings.
Right!
Some of the members have done all this blocking 'behind' the grille, thereby preserving the original aesthetic of the car. Blacked- out, or done in Plex / Lexan.
The extraneous outer portions of the bumper penetrations, same-same.
