Old 09-03-2021, 09:50 PM   #12 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
So does the EGR flow, either standard or increased.
There would be fewer oxygen free to react with the nitrogen in the air flow. Not so bad at all.
I wonder if adding propane via the EGR circuit would be helpful. Maybe put a very small propane carb (e.g. lawnmower carb) on it? Of course NOx would be worse.
Edit: Which NOx could be offset via water injection.
