Old 09-07-2021, 01:17 PM   #13 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
I wonder if adding propane via the EGR circuit would be helpful. Maybe put a very small propane carb (e.g. lawnmower carb) on it?
I guess it would not be of much help.
Of course NOx would be worse.
Most likely non-methane hydrocarbons would increase, while NOx would eventually decrease, unless the ECM would trim down the stock fuel injection flow.
Which NOx could be offset via water injection.
Had it been strictly to offset NOx, water injection would've been a more likely approach.
