Old 09-07-2021, 09:25 PM   #15 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
But with fuel and air entering through the EGR valve NOx will increase since the A/F mix will be stoichiometric with no inert gas like to exhaust gas to lower the combustion temps.
Depending on the proportion of fuel enrichment, it won't harm performance, it may actually lead to some improvement. On a sidenote, replacing the so-called inert gas with a gaseous fuel is more likely to decrease NOx, as it will decrease the amount of free oxygen molecules to reach with the nitrogen. A richer AFR is usually more likely to result on lower NOx, regardless of how the supplemental fuel is delivered to the intake tract.
