Old 09-08-2021, 12:44 AM   #4 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Just to be clear, you'd want all the air you can get to the evaporator. Low pressure lines can also be let out in the open (when used for heating only) since they will always be colder than ambient temperature, with or without wind chill. The only problem is you'll get ice build up on them if you do. But yes, the more you cover up the high pressure lines the better.
