Old 09-11-2021, 02:25 AM   #4 (permalink)
cRiPpLe_rOoStEr
My advice would be, rather than to try to fabricate into place Toyota's motor and differential, to gather all of the rear driveline stuff from an AWD ridgeline (knuckles, axles, differential), as if you were to be doing an AWD conversion. Except, rather than putting a driveshaft between the rear differential and a front transfer case, simply bolt an electric motor of your choice to it.
Finding a motor suitable to fit the same space a driveshaft would be supposed to go is far from being the easiest task, yet I remember some years ago there were plans to release one commercially. On a sidenote, too bad repurposing the setup of a CR-V or Accord hybrid into a Ridgeline would be mostly out of question.
