Old 09-13-2021, 01:13 AM   #418 (permalink)
cRiPpLe_rOoStEr
Originally Posted by 19bonestock88 View Post
It has what was referred to as compression sense ignition, which uses ignition current to figure out which cylinder is firing and thus derive a cam position signal. Kinda neat.
I knew about knock sensors, but I'm not sure to which extent they could actually measure the actual compression within a cylinder.
