Old 09-13-2021, 09:15 PM   #26 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
I guess the real question would be: could it be worth it?
Most likely it would be worth.
There are costs associated with fabricating a camless head. It didn't seem too much though as it can be done with a lot of off the shelf parts and simple machined pieces.
I'd be more concerned about the electronic control and how it would integrate to the ignition and injection.
But then there's longevity and the chance of destroying a good engine.
A cam belt slap is also quite expensive to fix.
But then there's the chance of greatly improving fuel efficiency and power at the same time.
Considering it would also eventually not require some components such as a throttle-body, and keeping port-injection would allow avoiding the OPF which is now required in Europe and the USA for gassers fitted with direct injection, it seems worth a try.
Isaac Zachary (09-14-2021)
