Old 09-17-2021, 02:01 AM   #39 (permalink)
freebeard
Did I err?
Originally Posted by DDG
DELTA Pro - EcoFlow
https://ecoflow.com/pages/delta-pro
A colossal 3600-7200W AC output makes DELTA Pro powerful enough for heavy-duty devices. If you need even more power, get up to 240V with the DELTA Pro and the …
________________
110v vs. 220v Wiring | DoItYourself.com
https://www.doityourself.com/stry/110v-vs-220v-wiring
With 220v wiring, both three and four-wire setups are possible. The red and black wires in 220v circuits carry 220 volts across each other but 110v in relation to the neutral, which is the white wire in a four-wire cable, leaving the green or bare copper wire for grounding the circuit.
220 Volt Appliances | 240 Volt Appliances
https://www.220-electronics.com/220-...ppliances.html
220 Volt and 240 Volt Appliances. We carry a large and robust selection of high-quality 220 & 240 Volt Appliances. From washers and dryers to kitchen appliances, personal products and more, we're sure to have exactly what you're looking for. As the leaders of international relocation since 1979 and with nearly 40 years of experience, we will ...
Voltage Differences: 110V, 120V, 220V, 240V
https://www.buildmyowncabin.com/elec...s-110-220.html
Voltage Differences: 110V, 115V, 120V, 220V, 230V, 240V. You'll often hear voltages in your home referred to as 110V, 115V, or 120V. This can be confusing but the bottom line is they are referring to the exact same thing. 120V is the AC voltage on a single hot wire in your home with respect to neutral (or ground).
Did I mention that I easily?
