Old 09-18-2021, 03:55 PM   #20 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Re: your second picture--
Pressure always acts normal to a surface. The arrows in the lower image are not correct.
A spoiler affects flow upstream because pressure is transmitted through air (fluid) at ~340 m/s. Fitting a spoiler may increase pressure as far upstream as the roof, as I found on my Prius with a small lip spoiler:
Gauge pressures with no lip spoiler
Gauge pressures with lip spoiler
Difference
Lip spoiler for reference
Les than $100 worth of equipment and a couple hours and you can measure yourself and find out what a spoiler does on your car.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 3 Users Say Thank You to Vman455 For This Useful Post:
aerohead (09-22-2021), COcyclist (11-11-2021), tomi_k (09-18-2021)
