Old 09-20-2021, 12:11 PM   #7 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Gen IV Prius have been having head gasket failures?
Top failures: at least 2010-2011 maybe even 2012:
Piston rings clogging
EGR cooler clogging
Head Gasket Leaking
If you make it far enough you will then be graced with a cell or two in the pack going bad.
Gen 3 is 2010-2015.
I have seen as bad as 300mi/quart on my car in an extremely mountainous trip, and right now driving it easy it uses a quart every 1500-2500. Starting to knock slightly around 1600rpm downhills on the interstate so the egr is gonna need to be cleaned. I am under the impression the egr cooler knock is usually what leads to the head gasket issue, but I am not an expert. Usually when it does this i just throw it into neutral and avoid the knock but i assume some people just drive through the knock until it gets pretty gnarly.
As for the battery I just make sure to stay above 50% SOC or preferrably around 58% (peak is 70% which keeps the engine on 24/7 so you wanna stay below that). If you go below 50% it will drop like a friggin rock down to 20%. But i stay above 50 and usually never have that issue.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
