Old 09-21-2021, 01:57 PM   #22 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Originally Posted by Autobahnschleicher View Post
Wood-gas is pretty terrible:
1. It is very inefficient
2. It requires a somewhat elaborate starting procedure
3. It reduces an engines power output massively
4. It makes your oil go acidic rather quickly
5. The emissions of an engine running on wood-gas are terrible
Use that plant material to make ethanol instead.
I've been reading up (out of curiosity) on wood gas. And you can set it up to run on gasoline/ethanol to get the firing process started then switch over to wood gas (via switches/valves in the car) after a few miles of driving. Making the startup not so elaborate procedure.
There is a study by the university of alabama showing comparable emissions to gasoline on an older (90's I think?) dodge v10 and 37% more efficient than gasoline.
I have to leave for work, but I will find the link to the study.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
freebeard (09-21-2021)
