Old 09-22-2021, 09:22 AM   #27 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by hayden55 View Post
Try the scan gauge. The dash is more of a dummy gauge.
State of Charge8216F101C9 0316844105C9 2808 00C800330000 SOC XX.X %
https://www.scangauge.com/support/x-...ommands/prius/
70% on scan gauge is full bars on the dash
I should have noted--I read battery SOC on the Scangauge. The dash indicator is useless and only vaguely correlates with SOC. In that picture, it was at ~76%.
Originally Posted by Autobahnschleicher View Post
Although a car beeing a VW instead of a toyota is probably a good thing in therms of reliability.
I've made the misstake of buying a toyota, and the amount of engineering failiures I've had to fix is insane.
*laughs in 22RE*
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
hayden55 (09-22-2021)
