Old 01-23-2008, 09:05 AM   #6 (permalink)
tasdrouille
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I've been thinking about how I would fasten wheel skirts on the car should I decide to make some. I've read a few DIYs and none I have seen seem like a great option. Ideally you'd want a tooless design that doesn't take long to remove. This obviously isn't the easiest thing for us DIYers. Here are a few things I was looking into. I'd like to hear from others.
Use locating pins on the top of the skirt. Then use a sort of stud on the chassis and a wing nut on the bottom to hold it on. Here is a rough idea.
Use multiple push-to-close latches. Possibly in conjunction with some locating pins on top. This would necessitate a rigid frame for the skirt.
I guess I'm curious how the OEM sideskirts are held to cars? Some sort of plastic snap would probably work great, but I haven't found any good ones readily avaliable.
I would just put pins sticking out where your wing nuts are and make U groves in the studs so the skirt will slide up in position. Now all I would need is a way to lock it at the top. I would probably use somekind of hook lock like the ones used on rooftop boxes.
www.HyperKilometreur.com - Quand chaque goutte compte...
