Old 09-24-2021, 06:34 PM   #29 (permalink)
tomi_k
Aerohead, thanks ! I think you are referring into Figure 14, on page 10 in the SAE 810185 (Fig, 14 - Influence of rear end slope inclination angle on drag coefficient).
My vehicle (pickup truck) has L0 / L -ratio of 0.3441 (without a tail extension) and L0 / L of 0.4087 (with the tail extension) as of today. For L0, I use trucks bed length (without and with the tail extension).
<quote>
I've done a linear interpolation between the 27% aft-body and 36% aft-body, tested and reported in Figure 4.59.
</quote>
So you interpolated that range, tested it and results fall into the interpolated line, correct?
The Following User Says Thank You to tomi_k For This Useful Post:
aerohead (09-24-2021)
