Old 09-24-2021, 09:05 PM   #283 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by Accordowner View Post
Why do people keep referencing this douche's videos as authoritative source of engineering knowledge!!?? In one of his videos, this dope says that putting an ICE car in neutral while driving is bad for the car!!!???
Why do people take a statement written in the context as applying to the general public, not even wait to see why the statement was made, and then want to compare it to their own niche use case that has nothing to do with the point in the video?
Of course you can benefit in certain vehicles from shifting into neutral. But can it be bad for the car? I know a guy who wrecked more than one transmission because he would shift into neutral and coast down long mountain passes with the engine off. (Most automatics and some manuals have a lubrication pump that only pumps when the engine is turning).
I also know of someone who went off the side of a mountain pass and killed several of his passengers because he was coasting down the hill in neutral and lost his brakes. (Lack of engine braking).
One other valid point this guy makes is that some engines will cut fuel during deceleration. Seeing how most people who are trying to slow down or stop are also applying the brake at the same time it makes more sense to leave the vehicle in gear, which cuts off fuel, maybe even downshifting a gear or two, and slow down that way instead of shifting into neutral and having the engine idle as you use up more of your brakes because you think you're doing your car a favor. ('You" referring to the general public).
But that doesn't apply to me in my Hybrids that shut the engine off while decelerating. Obviously I can get better fuel mileage if I pulse and glide by shutting off the engine and coasting in neutral until my speed comes down enough to merit accelerating again. So he didn't think of me and mention my roadrage inducing driving technique. Should I be offended?
