Old 09-26-2021, 12:37 AM   #51 (permalink)
cRiPpLe_rOoStEr
Originally Posted by EcoCivic View Post
I assume that other than only using it while braking in DFCO, the next best scenario would be using it at idle while coasting rather than while cruising or climbing hills?
Going downhill too, unless you need to pick momentum for a longer coasting on the route once the downhill stretch is over.
