Old 09-27-2021, 10:35 AM   #130 (permalink)
Piotrsko
Turns out you can't swap the CEL and SRS bulbs with LED. There's a constant low current which is enough to keep these bulbs lit, and they end up being dim or bright, rather than ever turning off.
You need a shunt resistor to bias that idle voltage
