Originally Posted by maanma
I think rear window wind guide should be bent smoothly downwards. Perhaps more diffuser guides could give improvement too.
I does touch onto the roof and I tried it bending slightly down, flat or up with no real difference. I could modify it for more angle up or down but I think it would start hurting at that point.
Originally Posted by oldtamiyaphile
Rake and lowering both should improve economy, you're probably driving harder now.
My 2.0 VTS gets the same economy and I mostly drive the wheels off it so you must be giving that rev limiter a proper work out
I swapped wheels and tyres when I lowered so no gains there(Went from skinny eco tyres to fat little chonky ones). Its about 70-80% round town so small gains to be had from aero with greater effect on the track but I should put my ECU in as the camshaft means it runs super rich at idle and I probably do drive too enthusiastically haha
