Old 09-28-2021, 02:18 PM   #52 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
First, most repairs in European brands are due to electrical issues not failures of the core drivetrain. Turbo failures are pretty rare from any manufacturer and generally go the life of the vehicle.
European brands also tend to do a lot better with proper maintenance. People in the USA have a bad habit of second guessing the manufacturer and using incorrect oils and other fluids. Either because it is something they have always used or just because they are cheap and don't want to spend the money for the advanced synthetics.
We also have a bad track record when it comes to doing regular maintenance outside of changing the oil. People will change the oil every 3,000 miles at the quick lube but never changing the transmission fluid and then are surprised when a dual clutch transmission fails. They never change their brake fluid then complain when an ABS module fails.
European brands engineer their products based on regular maintenance being done on time and properly.
So the rest of the car dies faster than the turbo can?
My Touareg said the transmission fluid never needed changing or even inspected. Maybe they too didn't think the rest of the car would outlast a never serviced 8 speed. I personally did trust the Aisin transmission more than any other part. The turbo did outlast the rest of the fuel system, but at 80,000 miles that's not saying much.
I'm sorry, I just don't think anything from Volvo, VAG, BMW, MB is above average reliable on any level of the car, certainly not Toyota reliable.
