Old 09-28-2021, 03:05 PM   #10 (permalink)
Autobahnschleicher
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
Originally Posted by Furai View Post
I suspect its due mostly to driving as its a fair amount of city, gearing means it does 3000rpm at 60MPH/100Kmh and the Cam is running with the factory ECU so doesnt fuel correctly(Would benefit from extra compression too)
I have tried some different pressures and normally run 38psi but it didnt make any noticeable difference, I used T1Rs a long time ago but if you tried the AD08R youd never go back!
Yea, my car is geared about the same, just with a larger engine.
My engine is also still running only 10:1 compression ratio, wich is kind of low.
Will probably try different tires at some point, but let's say my tires have quite a lot of life left in them still.
Also not sure if I can get them in the sizes I need, wich is either 185/55R15 and 205/50R15 and the alternative size was 195/50R15 and 215/45R15 if I remember correctly.
