Old 09-29-2021, 12:22 AM   #1 (permalink)
cRiPpLe_rOoStEr
How longer could the Ford Model T engine have eventually soldiered on?
With a production run was extended until '41 outliving at least 3 generations of other full-size Fords after the Model T itself, even though from '27 on the usage was more directed to special applications, the Ford Model T engine pioneered the hot-rod scene somehow. From high-compression cylinder heads to stroker crankshafts, performance-oriented parts are still available through specialized vendors, and eventually could enable the Model T engine to provide adequate performance even for some driving conditions closer to the modern ones. Sure it was already outdated at the time the Model T was phased out, but its peak power and torque RPMs lower than these same parameters on some heavy-duty truck engines are quite fascinating.
https://engineeringworkarounds.blogs...nsider-to.html
