Old 10-01-2021, 11:30 PM   #8 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Waspswatter View Post
I'm trying to get used to driving a hybrid. I was very soft on the brakes on my Ranger, but now I wonder if I should use brakes more to engage the regen. Also, I've been a member here for five or six years and JUST RECENTLY read up on how to do pulse and glide. I had heard that engines are more efficient under load but it must not have "sunk in". I would always slow down up hills and only start to speed up as I rolled over the crest, then using gravity to help me accelerate down the hill.
Can someone please invent a smart cruise control that will automatically pulse and glide for me.
Don't try to p&g your truck, it's not going to work. It's got the aerodynamics of a brick and that engine is already operating pretty efficiently under normal conditions.
Aside from the hybrid battery, the only thing that is going to be a maintenance issue is the afm (active fuel management) on that 6.0 ls engine. You can get a $200 plug in chip that will disable 4cyl mode or be proactive with oil changes and replacing the screen under the oil pressure sending unit. If $200 isn't a big problem for you, I'd go that route. Failure of an afm liter means an engine rebuild...
The Following User Says Thank You to ksa8907 For This Useful Post:
Waspswatter (10-02-2021)
