Originally Posted by ksa8907
You can get a $200 plug in chip that will disable 4cyl mode or be proactive with oil changes and replacing the screen under the oil pressure sending unit. If $200 isn't a big problem for you, I'd go that route. Failure of an afm liter means an engine rebuild...
Where do you get the chip?
