Old 10-06-2021, 07:28 PM   #228 (permalink)
oil pan 4
Originally Posted by Isaac Zachary View Post
Of course a gasoline engine could be tuned and designed to be more diesel-like. It could be made to run much leaner, have direct injection, and if sized correctly could run most of the time at full throttle making the turbo useful. If ran lean enough the engine will actually run cooler.
But things get even better with gaseous fuels like propane, natural gas and hydrogen. These can run much leaner, (30:1 for propane IIRC and even leaner for hydrogen) and practically not even need a throttle valve. Just enrich the AFR for more power, like in a diesel.
Seems only common in theory, all but non existent in practice.
