Old 10-07-2021, 09:12 PM   #15 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
I wonder if you have to pay extra to test for the detergents.
The Prius I got with over 200,000 miles on it apparently has gummed up rings. Although there are a lot of things in the design that contribute this common failure on Toyota engines, from what I can find the problem isn't an issue if you just change the oil every 5,000 miles or sooner which allows the oil to keep those oil control rings clean.
