Old 10-08-2021, 12:44 AM   #433 (permalink)
cRiPpLe_rOoStEr
Originally Posted by 19bonestock88 View Post
I would like to build a hybrid system into something similar to Honda’s IMA system, whereas the motor works alongside the engine, and helps with engine braking as well as acceleration. That seems to me a long ways out though.
The setup of some European-designed hybrid trucks and buses is somewhat like an improved IMA. Look for that ZF hybrid "modular" motor for trucks and buses and you'll know what I mean.
I figure with the turbo and the head work I could probably safely get to around 250whp without glaring risk of engine failure, which would be fun in a sub 2500lb car. Adding a hybrid system could potentially increase system output to ~275-280whp?
Presumably you could get an even higher combined power if that was the case.
