Old 10-13-2021, 06:20 PM   #50 (permalink)
cRiPpLe_rOoStEr
I like the original look better than the facelift version (2008) but the 2009 was the first with stability control.
The original look is quite clean, but the fake-chrome grille of the facelift version doesn't look so bad at all.
2009 also got a bigger engine with a bit more HP, throttle by wire and variable valve timing for a boost in efficiency.
I don't remember having ever seen a vehicle fitted with stability control and a cable-actuated throttle plate.
