This had been gestating in my mind and I went ahead and did a workup on it:
In Hucho et al.,SAE Paper 760185, Figure 24, and Hucho et al., 2nd-Edition, Figure 4.62, page 155, they lay out the effect of various aft-body configurations on total drag, for the Golf/ Rabbit, and Jetta.
There's enough visual information in the two figures, with which to reconstruct the actual 'shapes' of the two cars, to complement their associated drag coefficients.
The Jetta is just the Golf, with a little more than 10-inch ( 254mm ) trunk extension added to the rear.
An eleven data-point scatter-plot is provided for the Jetta, illustrating the Cd at each configuration, ranging from Cd 0.407, to Cd 0.365.
I drew out six (6) of the configurations.
* If the 'step' is removed from the Jetta, it produces a 'fastback' with a constant rear slope angle of 33-degrees, placing it in the forbidden region of bistable flow, which on the sibling Golf, generated up to Cd 0.44.
* If the step of the 'Basic Shape' is re-installed, the drag falls to Cd 0.407.
* The addition of the Basic Shape notchback step is clearly providing the same function as what one would seek from the addition of a rear spoiler.
* If 150mm of additional height is added to the Basis Shape, the drag falls to Cd 0.37.
* If 450mm is added to the Basic Shape, the drag minimum of Cd 0.365 is achieved, according to the scatter-plot.
* Adding 550mm to the Basic Shape degrades the flow to Cd 0.38, at Shape B.
The drag of the Jetta can be altered by delta-Cd 0.075 simply as a function of the rear body slope angle / step height.
In Hucho's Figure 4.60, by Buchheim et al., the 'curved-roof' wind tunnel model also registers a delta- Cd 0.075, also with the single rear slope angle parameter, by sweeping through 200mm of variable step height, indicating angles from 36-degrees, to 13-degrees.
If you're out and about, and happen to spy a late-model Accent, Rio, or Mirage notchback sedan, imagine what the rear slope would be without those boot/ trunk lids.
