Old 10-20-2021, 01:04 AM   #134 (permalink)
The Toecutter
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
Man, whoever gets this is one lucky SOB.
If I had a place to put this beast, I'd keep it roughly as aero as it is while Mad Maxing the **** out of it with 2" thick or more steel plating, bulletproof windows, maybe an extra 2-3" ground clearance, and then shove a tuned mechanical-injection Cummins inline-6 turbodiesel into it set up to make around 600 HP and 1,000 lb-ft of torque, with a big fat set of twin 50 gallon tanks in the back. I bet even at 7,500-8,000 lbs, it would probably get like upper teen MPGs in the city and maybe 35-40 MPGs on the highway like that. And like any wagon should, it would be good at hauling. Hauling ass that is!
The Following User Says Thank You to The Toecutter For This Useful Post:
Frankiec55 (11-17-2021)
