Originally Posted by EcoCivic
I always blip the throttle before shifting back into gear to speed up the transmission's input shaft to as close to the required RPM as possible...
Do you mean you blip it, push in the clutch, then shift, then re-engage the clutch?
If you blip it after you push the clutch in it won't spin the input shaft unless you have some clutch drag.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
