Old 10-22-2021, 10:03 PM   #9 (permalink)
EcoCivic
Originally Posted by M_a_t_t View Post
Do you mean you blip it, push in the clutch, then shift, then re-engage the clutch?
If you blip it after you push the clutch in it won't spin the input shaft unless you have some clutch drag.
Yes, I blip the throttle before pushing the clutch to shift. That way I manually speed up the input shaft to approximately the RPM it needs to be at instead of forcing the synchros to. It goes back into gear noticeably smoother this way.
The Following User Says Thank You to EcoCivic For This Useful Post:
Gasoline Fumes (10-22-2021)
